Radiator fans?
Go to solution Solved by skullbringer,
Scythe Gentle Typhoons or Noctua NF-F12s
Hello all!
I'm working on some water cooling plans (wrong sub forum eh? :P )
I need fans for my Radiator [Fans make this the right sub forum right?], and aesthetics aren't an issue (HAF Stacker means they're hidden).
What are the best Static Pressure fans (If it's not a solid answer, what are my options?)
I was looking at Gelid Wings for the case fans, and I wasn't sure about the rad fans. (Using Monsta 80mm thick Radiators)
Please and thank you for all help! :D
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/124406-radiator-fans/
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654839
So, I really like the Typhoons, but all of the listing on Amazon (US) say "Case fan". Is that Amazon being non-techy, or are there different ones?
Holy crap! NF-F12's are 25 bucks PER! When you need 18... That adds up lol...
http://www.amazon.com/s/ref=a9_sc_1?rh=i%3Aaps%2Ck%3Agentle+typhoon&keywords=gentle+typhoon&ie=UTF8&qid=1394160983
Thats the Amazon link for a search of Gentile Typhoon. All say Case fan (and one thats 4k RPM [Noisssyyyy])
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654848
Price range?
Noctua NF-F12
Noise Blocker Eloops
Silverstone AP123
Scythe GT
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654850
Price range?
Noctua NF-F12
Silverstone AP123
Scythe GT
I need 18, so I want under 300 dollars for all, but if it's a definitive winner, I can go up to like 350-400.
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654859
Wait for the Noctua Black essence fans :P
btw you want eighteen fans is that for a push pull configuration?
also if you have only half the amount + in pull it would reduce the dust build up and hassle of cleaning & lower rpm for somewhat greater overall pressure
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654877
One, looks don't matter ;P
Two, if they price the same as the NF-F12's, they're 25 bucks per (400+dollars for my needs)
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654882
that is why i updated it and said buy half the quantity
The reason for Push/pull is the radiators are 2-3 times thicker than a normal rad. It's an 80mm thick radiator.
Are the Gentle Typhoons listed on Amazon Case fans, or are they the right ones?
-snip-
Around 20 bucks a fan at max.
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654929
when theyre 120mm you can mount them to either a cse or a rad. All fans can be categorized "case fans", so yeah, they are the right ones
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654947
even though your radiator is that thick doesnt require so many fans
take a look at Tiny Tom Logan"s Video playist under Orca on Youtube + i think that it is ridiculous to have eighteen fans in an entire system even for watercooling
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1654997
I've seen Orca. :)
I want to be able to crank them down. I agree with your statement, I'm not trying to argue... It's part for the overkill, and part for noise.
I'm going to go with the Typhoons :)
Thanks all.
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1655017
I've seen Orca. :)
Thanks all.
I guess you are right I was about to go on a rant lol but erm yeah whatever can satisfy your needs was gonna also link in his video about the aio cooler from corsair + the forty fans he added onto the radiator >_>
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1655030
Was quite the amazing set up :P
https://linustechtips.com/topic/124406-radiator-fans/#findComment-1655074
