Hello, so I posted about a new build sometime this summer but I've held off to wait for new parts and to have my budget for the build to be finalized. This will be a higher end pc that I need to use for my architecture programs for school as well as game very well. The programs I will be running for architecture is the adobe suite, revit, rhino, 3ds max, indesign, lumion, sketchup, enscape, and for gaming obviously the steam library, and epic library. I school work will come first so im more worried about it being able to run those programs well. I know a little bit about what parts are good I just couldn't explain how. My question would be can a high end gaming pc run all those programs well and with the new gpu specifically the 3080 is there any new requirements to get the best out of that card, like will I need a different motherboard or any other part? Also I have been tinkering with parts recently and I will list them below for suggestions and or changes, Thanks for all the help in advance!
CPU: AMD Ryzen 9 3950x
CPU COOLER: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler
Motherboard: Gigabyte X570 AORUS PRO WIFI ATX AM4 Motherboard
Memory: Corsair Vengeance RGB Pro 64 GB (4x16 GB) DDR4-3200 CL16 Memory
Storage: Western Digital BLACK SERIES 2 TB 3.5" 7200 RPM Internal Hard Drive
Storage: Corsair MP600 Force Series Gen4 1TB M.2-2280 NVME SSD
Video Card: NVIDIA RTX 3080
Case: Corsair Obsidian 500D RGB SE ATX Mid Tower Case
Power Supply: Corsair HX1000i High-Performance ATX Power Supply 80 Plus Platinum certified 1000w
https://linustechtips.com/topic/1243839-work-stationgaming-pc-build/
For 3ds max arc you should consider a quadro card, does not have to be a top end model either. Geforce cards have a hard time rendering complex wire frame structures in real time. Also why a 2.5" HDD instead of a 3.5" ?
I'd go with 2 WD Gold in Raid 1 instead. If you like the case sure but in terms of cooling or air flow it's average at best.
If your work stuff has priority, consider ECC memory (3200 available as well but CL22 and more expensive, also no RGB)
The hard drive is actually 3.5" I just mustve typed it in wrong. Also the case is still not set in stone. I've changed it a few times. Thanks for your help.
