I have 3 options for a power supply
Corsair RM850x- 7, 200price
Seasonic PX 850- 6, 900
Seasonic Focus GX 850- 6,200
Which one's the best among them? I currently have a Seasonic 660w platinum and I wish to upgrade to 850w. Help me asap!! And provide info plezz. They're all nice i think. should i go for a platinum seasonic px or the rm850x or should i just buy the cheaper one? THANKS
https://linustechtips.com/topic/1243713-help-me-choose/
I'd get the RMx, but
why
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996116
why exactly? if you're going to upgrade to ampere then check the power consumption for these cards first and check if you need an upgrade first or not, and i doubt you'll need one.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996121
going to buy rtx 3080.
wait for ampere to actually launch and check power consumption first before upgrading the psu, what other parts are you pairing it with? a 650w unit should be enough for a 3080.
Build Log:
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996131
electricity here is so sketchy that's why i just wanna be safe 😅😅
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996146
1 minute ago, pcvolv said:
going to buy rtx 3080. nvidia recommended 750 but 750 and 850w psu are around the same price
Unless you're running an HEDT CPU or a 10900K clocked at 5.2GHz+ on all cores, 660W should be plenty.
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996149
what does that have to do with the 3080's power consumption? lol.
getting a higher wattage psu change anything lol. for the most part a 650w should be enough for a build with a 3080, unless you're pairing it with super power hungry cpu's like hammered HEDT's or a hammered 10900k.
Build Log:
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996151
I currently have a 7700k to pair with the 3080. Ill upgrade it soon down the line. Im just gonna buy the 3080 coz i have no gpu right now. Will the 660w be enough?
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996182
Yea it should be more than enough.
Build Log:
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996184
But just in case i upgrade my cpu which of the psu will you recommend
depends on what cpu you upgrade to, for the most part this psu should be enough.
Build Log:
https://linustechtips.com/topic/1243713-help-me-choose/#findComment-13996197
