Case for top mounting the Arctic Freezer II 280?
Hi, i'm looking for a case with enough clearance to top mount the Arctic Freezer II 280mm, the case needs to have at least ~70mm of clearance between the mobo and the top.
I've tried with the DeepCool Matrexx 55 Mesh and soon enough discovered that the rad fan is blocked by the ram "clips", and had to remove both of the heat spreaders from my Asus Z-390F
Budget around 100€, preferably from "Amazon Italia".
Lancool II Mesh
As a wise master once said,
Put as much effort into your question as you would expect a stranger to add to their answer!
Desktop: AMD Ryzen 5 3800XT | Gigabyte X570 Aorus Ultra | Corsair Vengeance LPX 32 GB 4000Mhz CL18 | MSI RX 5700 XT Gaming X | Two WD Black SN750 1TB NVMe SSD | Corsair AX850 Titanium | Fractal Design Define 7 White, Solid
Laptop: Apple Macbook Pro 16 | i9 9980H | 16 GB RAM |  1TB SSD | AppleCare+ | Space Grey
Peripherals: RAMA U-80 Lake | Logitech MX Master 3 | Kanto YU2 White + Beyerdynamic DT 177X GO
Displays: LG GX 55"| Acer XB273K | Dell Ultrasharp U2720Q | LG 32UN650-W
Phanteks p500a. That should have 65mm clearance on top, and thats the thickness of LF II 280 with fans.
one question, can I install 3x120mm fans in the front?
I cant see why not. Although 3x140 should be better.
well nvm, the p500a here in Italy or that ships to Italy is all out of stock or overprice.
any alternative around 115€ or I should just wait 1 month when is back in stock?
  • 11 months later...
I know this is thread is quite old but, was it physically unable to be installed into the matrexx 55 due to ram/mb clearance or was it just covering the ram?
