I have a deepcool 55 matrexx mesh and b450 tomahawk max which has 3 pin connector and my fans have 2 pin cable so I used a converter. But now whenever I use any RGB effect like breathing a voltage fluctuation occurs where the RGB turns off stopping the fans too and then it starts again. I have to put the effect on static only which sucks so please someone give a solution. I also have a liquid cooler so I want all my fans to sync with motherboard
https://linustechtips.com/topic/1243652-cabinet-rgb-help/
2 pins fans should not use power from the motherboard.
You should plug it with a molex to 3 pins adapter so it will draw power from the PSU.
https://linustechtips.com/topic/1243652-cabinet-rgb-help/#findComment-13995650
i have b450 tomahawk max which has 4 pin connector and i have a deepcool matrexx 55 mesh case which has 3 pin fans so i used a converter and now when i change any rgb effect there is wierd rgb blinking and voltage fluctuation and i have to stick to static only. please help.
https://linustechtips.com/topic/1243652-cabinet-rgb-help/#findComment-13997787
as far as i know, the 4th pin is for the adressability of those fans. Therefore, converting them from 4 to 3 makes you loose this one lane that gives you the possiblity to change the RGB mode and color while trying to force the information of the 4th lane somewhere between/in one of those 3 left.
Obviously, if you then try to change it, shit like this happens.
But i might be wrong.
Remember: If you want me to see your reply - Quote me!
If your question has been solved, please mark the thread as solved by choosing the answer that has helped you the most as the correct/solving one.
Please also use appropriate titles. Titles should be a short description of your situation to get people interested in looking at your thread. Titles such as "help" or "i have a problem" (etc.) will only lead to you getting less to zero help, cause people won't be able to tell what this thread is about and therefore don't bother looking into it.
https://linustechtips.com/topic/1243652-cabinet-rgb-help/#findComment-13997794
6 hours ago, Yebi said:
What kind of a converter? 3-pin and 4-pin RGB connectors are completely incompatible. One is 5V, data, and ground; the other is +12V+pwm (x3) and ground. You'd need something with processing power in it to convert one signal to another
can you suggest any converter for that?
i dont know then how can i sync rgb with my motherboard
Well.. buy compatible components in the first place.
if your case comes with stock RGB fans, it usually comes with a dedicated RGB header. Just use that.
You wont be able to sync all of your RBG products with one click, but with 2 or 3. And if you dont want to change your color ever 30 minutes, you should be fine.
https://linustechtips.com/topic/1243652-cabinet-rgb-help/#findComment-13997919
Guest
