15 minutes ago, Zinic said:
Hey guys,
I built an LED project that displays the audio frequencies of any song in real-time and the outcome is pretty neat. I have lots of examples and provided a build log of the project on imgur.
https://imgur.com/gallery/tSoa2W6
Neat project you got there! I don't think I would be able to look at that for more than a few seconds though. I imagine my eyes would get tired pretty quickly
Any plans for VU meters in the future?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Awesome...
The number of leds is a bit odd, you went with 47x60 = 2980.
My first thought was "this sounds like a good opportunity to make some RGB tiles"
I would have made a 12 x 9 circuit board, and get 6..7x4 = 24..28 boards made ... ending up with 56..65x48 dot matrix screen.
There's a chip IS31FL3741  which does 39x9 dot matrix and is rgb aware, so each board could have 13x9 RGB leds, but I figured 12x9 would make for easier math ... : http://www.issi.com/WW/pdf/IS31FL3741.pdf
At 15mA per color, you have maximum 5A, so you could easily add a 3.3v .. 3.6v dc-dc converter on each board to reduce losses and be able to use cheaper power supplies.
A 12v ATX power supply would be enough  5A x 3.6v = 18w ... let's say 20w per panel to account for conversion losses... you're looking at 28 boards x 20w = 480w on 12v ... so a single 650w atx power supply would have worked.
RGB leds can be cheap, Digikey is typically more expensive yet they can be as low as 11 cents per led at 1000pcs in a very easy to solder package: https://www.digikey.com/product-detail/en/broadcom-limited/ASMB-KTF0-0A306/516-3906-1-ND/7917025
TME.eu has them for around 25..60 euro / 1000pcs :
https://www.tme.eu/gb/details/rf-w2sa50ts-a39r/smd-colour-leds/refond/
https://www.tme.eu/gb/details/rf-w7sp30ts-a44/smd-colour-leds/refond/
https://www.tme.eu/gb/details/rf-w2sa30bs-a15-we/smd-colour-leds/refond/rf-w2sa30bs-a15-we/
https://www.tme.eu/gb/details/fyls-5050nrgbc/smd-colour-leds/foryard/
JLPCB or others will make 5 boards for 10$ or whatever, and you can order a steel stencil for solder paste and you place the leds on the circuit board and heat up the board from the bottom and your leds are soldered
