Posted September 5, 2020 Hello! This is my first time here in the forums and I am here because I need your help! I am looking to build a new PC when the 3070 drops as it has been about 6 years since I built my current rig which is fitted with an Intel i5 4690K. I need to know which CPU to pair with a 3070. The options are the AMD Ryzen 7 3800X or the Intel i7 10700K. Any thoughts or comments would be appreciated. My friends are all AMD fanboys so I am getting a lot of peer pressure to go AMD but would like an outside voice just to make me feel better about the decision. Thank you! Link to comment https://linustechtips.com/topic/1243102-i-need-your-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2020 Are you just gaming? Id say Intel 10600k or 10700, not the 10700k as its almost 120$ more then both the 10600k or the 10700 and performance will be about the same. 3800x isnt worth buying unless its only 10$ more then the 3700x, they are the exact same cpu just one is binned a bit better if you plan to OC at all, although it doesnt always work out that way. My Gaming and Editing Rig : http://linustechtips.com/main/topic/500716-red-gaming-build/ Link to comment https://linustechtips.com/topic/1243102-i-need-your-help/#findComment-13991803 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2020 2 minutes ago, psawki said: Hello! This is my first time here in the forums and I am here because I need your help! I am looking to build a new PC when the 3070 drops as it has been about 6 years since I built my current rig which is fitted with an Intel i5 4690K. I need to know which CPU to pair with a 3070. The options are the AMD Ryzen 7 3800X or the Intel i7 10700K. Any thoughts or comments would be appreciated. My friends are all AMD fanboys so I am getting a lot of peer pressure to go AMD but would like an outside voice just to make me feel better about the decision. Thank you! This video might help you..... Link to comment https://linustechtips.com/topic/1243102-i-need-your-help/#findComment-13991805 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2020 3800X easy decision, because AMD has a better overall platform. Intel platform lacks the PCIe Gen 4, which could be a bottleneck. CPU: Intel Core i7 8086K, Delidded with Der8auer Custom Nickel-Copper IHS and Coollaboratory Liquid Ultra CPU Cooling: Scythe Ninja 5 with Thermal Grizzly Kryonaut Thermal Paste Motherboard: ASRock Z370 Taichi RAM: 2x16GB Kingston Predator DDR4 3200 MHz 15-17-17-36 GPU: Gainward RTX 2080 Phoenix GS with Raijintek Morpheus II Core Black Heatpipe VGA Cooler, Thermal Grizzly Kryonaut Thermal Paste and 2x Scythe Kaze Flex PWM 120mm fans Case: SilentiumPC Regnum RG4T Pure Black TG Storage: Samsung 960 EVO 250GB, Samsung 970 EVO 500GB, Seagate ST4000DM 4TB HDD, Toshiba HDWD240 4TB HDD PSU: SilentiumPC Supremo FM2 Gold 750W Case Cooling: 6x Scythe Kaze Flex PWM 120mm fans Keyboard: Corsair Strafe Mechanical Keyboard Mouse: Trust GXT845 Tural Display: Sharp LC-50LD265E Operating System: Windows 10 Link to comment https://linustechtips.com/topic/1243102-i-need-your-help/#findComment-13991808 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2020 Usecase? If it’s gaming the 10700k is better, no contest. Link to comment https://linustechtips.com/topic/1243102-i-need-your-help/#findComment-13992084 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 5, 2020 14 hours ago, H6NS said: which could be a bottleneck. You don't or can know that. and heck even nvidia said gen 3 should not be a problem, and a 3080 should not saturate gen 3 x16 bandwidth, only way for us to know is to wait for ampere to actually launch and check. 14 hours ago, psawki said: The options are the AMD Ryzen 7 3800X or the Intel i7 10700K. Any thoughts or comments would be appreciated workload? assuming it's just gaming, the 10600k is more than enough and performs similarly as games do not scale up to 8 cores. but strictly between these two and assuming this is a gaming rig, 10700k. PC: Motherboard: ASUS B550M TUF-Plus, CPU: Ryzen 3 3100, CPU Cooler: Arctic Freezer 34, GPU: GIGABYTE WindForce GTX1650S, RAM: HyperX Fury RGB 2x8GB 3200 CL16, Case, CoolerMaster MB311L ARGB, Boot Drive: 250GB MX500, Game Drive: WD Blue 1TB 7200RPM HDD. Peripherals: GK61 (Optical Gateron Red) with Mistel White/Orange keycaps, Logitech G102 (Purple), BitWit Ensemble Grey Deskpad. Audio: Logitech G432, Moondrop Starfield, Mic: Razer Siren Mini (White). Phone: Pixel 3a (Purple-ish). Build Log: Link to comment https://linustechtips.com/topic/1243102-i-need-your-help/#findComment-13992106 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
