2080ti OVERHEATING
1 minute ago, Gitesh1909 said:I think i cannot RMA it, because the card is out of warranty, although i will try it. and what if i changed the liquid from the loop and try to fix the loop leak? what kind of liquid it needs, distilled water? any suggestions. or is it better to use new custom liquid/air cooling for the gpu.?
My ASUS Zenwatch was out of warranty aswell when the display cracked and yet they fixed it free of charge. So there is a good chance that they can help you out.
Distilled water would be fine, but flushing it out and adding an anti-microbial mix would be better.
I would not recommend that tho, because it is likely to leak again, even if you think you fixed it.
These loops aren't designed to be taken apart and filled again.
It would be best to find a new cooler that fits that PCB.
The NZXT Kraken G12 for example only fits 2080Ti reference designs.
Your best bet is to hope that ASUS can help you.
