I'm getting the RTX 3070 and pairing it with Ryzen 9 3900X and I don't know what motherboard to get. I need 2 slots for ssd and I heard about the PCIe gen 4. Any boards you recommend under 200 bucks? Two or three with wifi would be great. If you have a really good one that doesn't have wifi, I can run Ethernet if needed. Thanks
https://linustechtips.com/topic/1242600-need-help/
27 minutes ago, AndrewZScorpion said:
Definitely would want to spend more than $200 on a motherboard if you are planning to overclock. Also might want to rethink a 3900x with a 3070, the 3080 would be a better fit.
I don't plan on overclocking and definitely not going to pay 700 plus tax for a GPU. I'm only getting the 3070 because it's a great deal.
https://linustechtips.com/topic/1242600-need-help/#findComment-13987843
1 hour ago, AndrewZScorpion said:
The Gigabyte X570 AORUS ELITE WIFI looks pretty good to me, I’ve never used it though so you might want to look into reviews more in depth than I did. From what I saw they were very positive.
Yea that's a great board, I'll take that one thanks.
https://linustechtips.com/topic/1242600-need-help/#findComment-13988139
