Other system specs? 3080 has a max TDP of 320W, but if you've got a less power-hungry CPU, you'll probably be fine.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987732
3080 has 2x8pin connectors so up to 375 watts, it will probably work fine even with a 125watt CPU not overclocked.
However 750watts is recommended and really would be better for the potential power draw if your system went max load on all components for some reason.
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987755
I have only a Ryzen 5 3600, 16gb ram, also will this be a bottleneck?
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987756
without seeing a proper review it's hard to say. 1440p is less cpu bound so there shouldn't be noticeable bottlenecking. Even looking at 1080p this card will overdrive high framerate monitors on any CPU.
600watts would be fine for that build. 3600 tops out at 140 watts, adding the 3080 would still only top out around 500watts so you'll be well within spec
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987806
The maximum possible power draw on the connectors isn't really a good metric of TDP. The manufacturer's estimation (which they have tested rigorously) is going to be more accurate.
Main PC:
Peripherals/Other:
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987808
Should be fine. System power draw, aside from CPU+GPU, is typically minimal, and the 3600 isn't a super power-hungry chip.
Main PC:
Peripherals/Other:
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987810
it's an overestimate based on the theoretical maximum power the card could draw on bursty loads or when ramping up. TDP is the thermal dissipation which the gpu chip alone will have not adding fans, ram, rgb etc also at stock specs and not overclocked or boosting above the stock clock speed.
https://linustechtips.com/topic/1242599-please-help-me-decide/#findComment-13987817
