I'd like to know how to extend my battery life span (limit the wear of  the battery over time). Any tips or habits that i should be aware of.
I have a Lenovo ideapad flex 5, and i'm impressed on how little time the battery takes to recharge. I heard somewhere that charging a battery at a fast rate can be more damaging to it, than charging at a slower rate (take this with a grain of salt of course). Maybe there's a mode that charges my battery faster? What do you guys think?
Thanks in advance.
https://linustechtips.com/topic/1242464-extending-battery/
Don't charge over 80% to minimize charge cycle wear. Don't run to 0% battery. Don't try to start up if the battery might be drained out. General li-ion battery care.
I don't think fast charging is a problem at lower levels, but I'm no expert
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1242464-extending-battery/#findComment-13986737
4 hours ago, Lilbat said:
By the way, is it worth buying a replacement battery now ?
I wouldn't, batteries discharge over time and when li-ion batteries get fully drained I understand it to be a bad thing for them
desktop
HTPC
https://linustechtips.com/topic/1242464-extending-battery/#findComment-13990196
