Hello, people.
I'm building a workstation PC to allow me to use it for college work. I've got a budget of £600 and I study advanced engineering. This means I'll be using the PC for a lot of CAD work.
I also wish to use it for the occasional bit of gaming and I will also use it for Blender too.
I have the following in mind:
-Ryzen 5 2600X
-AMD RX580
-Corsair CX650
-16GB DDR4 3200mhz Corsair Vengeance
-Crucial MX500 500GB SSD
-ASUS Prime B450MA Motherboard
Workstation builds certainly aren't my strong point so if anyone has any better suggestions then that would be greatly appreciated :)
Thanks ;)
https://linustechtips.com/topic/1242280-workstation-build/
I would wait for the Ryzen 4000 series in just a few months. Can you wait?
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985332
you sure you want it to be a desktop? a laptop might suit college life better.
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985356
Laptops are a bit too expensive for me. I need a decent PC because the software used is quite intensive. And I can't afford a laptop of a similar spec sadly.
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985406
For the budget, I don't think you could do better. What's your region?
Main Rig :
Laptop :
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985442
Considering the circumstances, I'd presume you're not keen on deal hunting. If you do, it could be a good way to get more performance.
Main Rig :
Laptop :
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985679
I just need a machine that's decent enough to cope with the software. And a bit of occasional gaming on the side
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985737
I'd say your build is solid. For the case, I'll suggest the Thermaltake Versa H18. It's a great budget case with front mesh, good airflow. Alternatively, if your budget allows it, there's also the CoolerMaster NR 400. IT's a newer case and it also has solid thermal performance.
Main Rig :
Laptop :
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985807
Thanks!
https://linustechtips.com/topic/1242280-workstation-build/#findComment-13985887
