I'm pretty good with intel. i know all the cpus and were they are placed and there sockets and the chipsets to match. but with amd i know nothing so if some one could put the cpus in order of performance and what socket they go in and what chipset they go to that would be very helpful. hopefully that made sense
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/12413-help-with-amd-cpus/
Piledriver/Vishera 990FX, 990X & 970A Chipsets on the AM3+ Socket.
FX 8350
FX 8320
FX 8300
FX 6350
FX 6300
FX 4350
FX 4300
FX 4130
Bulldozer/Zambezi 990FX, 990X & 970A Chipsets on the AM3+ Socket.
FX 8170
FX 8150
FX 8130
FX 8100
FX 6200
FX 6100
FX 4170
FX 4150
FX 4100
http://en.wikipedia.org/wiki/Bulldozer_%28microarchitecture%29
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-132200
FX 8350
FX 8320
FX 8300
FX 6350
FX 6300
FX 4350
FX 4300
FX 4130
FX 8170
FX 8150
FX 8130
FX 8100
FX 6200
FX 6100
FX 4170
FX 4150
FX 4100
so the lower the number the better?
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-132350
No, the higher the number the better.
oh the response made it seem the other way
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-132527
Another thing to consider is that some of those are Black Edition processors meaning that you can do multiplier overclocking. Don't let that deter you from buying a non-BE chip though since nearly all AMD chips OC well right out of the box.
Desert Storm PC | Corsair 600T | ASUS Sabertooth 990FX AM3+ | AMD FX-8350 | MSI 7950 TFIII | 16GB Corsair Vengeance 1600 | Seasonic X650W I Samsung 840 series 500GB SSD
Mobile Devices I ASUS Zenbook UX31E I Nexus 7 (2013) I Nexus 5 32GB (red)
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-133496
I have an 8350 at 4.7 from 4
and a 4100 at 4.2 from 3.6
so easy to overclock these chips
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-133540
All FX CPUs have unlocked multipliers.
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-134169
I have a 8120 at 4.6(can go higher) from 3.2 B)
And yeh all FX are unlocked and OC easily.
FX 4=4 core- 2 Modules
FX 6=6 core- 3 Modules
FX 8=8 core- 4 Modules
Then the number after are 1 for Bulldozer, 3 for Piledriver, then the X0 on the end is the higher for better.
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-134250
All FX series processors are fully unlocked right out of the box. They were built for overclocking.
I have an 8120 running at 4.0 GHz on the stock cooler.
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-134325
Amd sticks with the same socket for a really long time, unlike intel coming out with some 4 new sockets each year >_<
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-134326
Fail on my part. I forgot guys lol.
https://linustechtips.com/topic/12413-help-with-amd-cpus/#findComment-134482
