Just had a new PC, about 2-3 months ago. Recently, I had experiences when I have chrome, MS Teams, and MS whiteboard open, it just freezes. And when I move the mouse to click off the applications, it just beeps. My keyboard as well does not respond in this scenario. Could I please ask for assistance? Thanks!
PS: I only have 8gb of 2666mhz of ram from hyper x
https://linustechtips.com/topic/1241285-freezing-and-buzzingbeeping/
Software or hardware beep, i.e. is it coming out of your speakers/headphones, or is it actually emanating from your motherboard? Also, if you could screenshot your Performance tab in Task Manager when it happens that might give us some idea of what exactly is going on.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Software, coming out of my earphones. Sadly I can't take a screenshot cause I can't use my keyboard or my mouse during this. It still works, but clicking won't do anything. Also, when this happens the audio playing still works, it is just everything else does not function.
Just had a new PC, about 2-3 months ago. Recently, I had experiences when I have chrome, MS Teams, and MS whiteboard open, it just freezes. And when I move the mouse to click off the applications, it just beeps. My keyboard as well does not respond in this scenario. This is through software, coming out of my earphones. Sadly I can't take a screenshot of my task manager cause I can't use my keyboard or my mouse during this. It still works, but clicking won't do anything. Also, when this happens the audio playing still works, it is just everything else does not function.
This is the screenshot of my task manager anyway with chrome and teams open but with it fully working.
By any chance I need to get a graphics card or more ram? Since I am only running integrated graphics though I am able to play games like valorant without any problems. It is just it happened to me already 3 times. May I also add that sometimes my pc won't boot and requires me to press the off/on switch untill it boots up. What could be the problem?
Hmm I've never had this issue so I can't start to guess
Can I get the full spec of your PC?
CPU
Ram
Motherboard
PSU
you can try running memtest86 to check your ram stability
-sigh- feeling like I'm being too negative lately
CPU
Ram
Motherboard
PSU
Ryzen 3200g
Hyper x 8GB 2666MHz
MSI A320 - A Pro
Generic Power Supply (came with case)
can i get a photo before i decide it's a bad one? (most probably is but still)
nothing else seems wrong
Are there any recommendations you  have for like 20-30$? Or is that too low a budget?
how much is a corsair CX450? or CX550? (i think $60 to 70-ish?)
that's the lowest i would go for a reliable PSU
you can refer to this list to look for cheaper models
Will take a look at the prices, thanks by the way for the help. Will update you when I get the PSU.
