Compatibility - CPU Cooler + Case Fans
TrizziMate
Go to solution Solved by MrBrightSyde,
...You know PCPartPicker already tells you on the page near the top (though sometimes they can't confirm compatibility due to either parts being very old or very new, or lack of specs of the parts)
But yes, they should work together.
Hi. Just was hoping to get some help from someone to tell me if the CPU Cooler and Case Fans in this list are compatible with the rest of my components.
List:
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 2600 3.4 GHz 6-Core Processor Purchased For $0.00
CPU Cooler Cooler Master Hyper 212 LED Turbo White Edition 66.3 CFM CPU Cooler $65.00 @ Centre Com
Motherboard Asus ROG STRIX B450-F GAMING ATX AM4 Motherboard Purchased For $0.00
Memory Kingston HyperX Fury 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory Purchased For $0.00
Storage Kingston A400 120 GB 2.5" Solid State Drive Purchased For $0.00
Storage Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive Purchased For $0.00
Video Card Gigabyte Radeon RX 580 8 GB GAMING 8G Video Card Purchased For $0.00
Case Fractal Design Meshify C ATX Mid Tower Case Purchased For $0.00
Power Supply Corsair RMx 550 W 80+ Gold Certified Fully Modular ATX Power Supply Purchased For $0.00
Case Fan Corsair 52 CFM 120 mm Fans 3-Pack $49.00 @ Centre Com
  Prices include shipping, taxes, rebates, and discounts
  Total $114.00
  Generated by PCPartPicker 2020-08-31 15:27 AEST+1000
I am open up to recommendations but if these are compatible I am probably going to stick with it most likely.
Thank you!
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
35 minutes ago, narrdarr said:
it will fit fine, but there are better options
are you looking for a white cooler?
I am looking for something white yes, I'll be changing to a white case soon.
Yes I know about this, just wanted to double check due to it being inaccurate sometimes.
Front fans and top fans can be 140 mm in the meshify C. Bigger fan -> lower RPM -> less noise.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Off the top of my head
PHANTEKS PH-TC14PE( much better but pricier)
deepcool neptwin white (is ok)
oh
Freezer 34 eSports DUO( better and cheaper than the 212 you have chosen)
PHANTEKS PH-TC14PE
I think this one does not support the AMD Ryzen 5 2600's AM4 socket, unfortunately.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
2 minutes ago, narrdarr said:
Oh, my bad. My website seems to have old data because the PH-TC14PE is in stock since 2012 x)
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
212 LED is not the cooler you want. Not at that price point either. Its actually bit worse in performance/noise than 212 Evo even thought its newer.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
