(the title actually is quite catchy... LOL)
I currently have 2x 24" Dell monitors. They have DP, DP-Daisy chain, and 2x HDMI, plus USB hub.
I currently use the DP on my RX 580.
BUT, do I need dual monitors? Waaaay back with the CRT monitors were around, I always did dual monitors because the screens were so tiny. And at the time, I was working with HTML CSS, PHP. It was nice to have Dreamweaver on one monitor and your browser on the other.
I read several reviews on it on YT, and it's just personal preference and usage.
I'm not looking at getting Linus's BIG wide monitor... But something smaller.
I'm currently using ArcoLinux (fork of Arch) and I do hope to go to a tiling DE. Like i3, Awesome, or Enlightment. That way I can have it spaced across the screen.
Budget does not matter yet, as I have to wait a few months.
https://linustechtips.com/topic/1240601-two-screens-or-not/
so you just want an ultrawide? theyre nice if that appeals to you, theres like 3 or 4 different sizes
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1240601-two-screens-or-not/#findComment-13971743
@Mind_001 honestly it is up to how productive you are or want to be ... I use 3 screens, look at my specs in my sig.
I both work and Game on this, I also find I can work and research at the same time.
Multiple screens is a preference thing really.
Here is a photo, I do a lot at once. Just for reference the tv is 32inches.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1240601-two-screens-or-not/#findComment-13971905
