Fm2 / Fm2+ help
Go to solution Solved by WoodenMarker,
Yes, they are the same.
Building a system based off the AMD value build guide but looking for a better Cooler than the bundled heatsink.
Suggestions welcome (AMD a10 6790k / Gigabyte f2a88xm / Fractal Design core1000)
also could you answer this please.
Are Fm2 and fm2+ mounting systems the same. there are not a lot of coolers listing fm2+ compatability and I'd like to be sure before buying a fm2 cooler for my fm2+ board
https://linustechtips.com/topic/124039-fm2-fm2-help/
https://linustechtips.com/topic/124039-fm2-fm2-help/#findComment-1650151
