Hello, good day to you all. I come baring a really dumb question for something I did which I did not really paid attention to when it happened. So I turned my PC off without unplugging or switching the PSU switch to off. Then I proceeded to unplug the 24 pin connector out of the PSU (modular psu) and the motherboard because I wanted to reroute it through another opening. Although nothing happened, no sparks, and the PC turn on just fine after. I thought about it after its done and realize that there are still power in the motherboard if the psu isn't turned off. Could I have done long term damage to my system? Or perhaps something happened that I don't know? Just want a peace of mind knowing nothing will happen.
Thanks to all who can replied
https://linustechtips.com/topic/1239958-possible-damage-to-system/
Don’t have much experience in this type of thing, but from what I’ve heard if it did damage, you would have noticed by now.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
1 minute ago, VLumar said:
Is it even possible for problems to occur after the fact?
Always possible, but extremely unlikely. I've never heard of anything like that ever happening.
You're fine, no damage done.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
No, if it’s working, it’s fine. But yes, always unplug PSU or flip the PSU power switch, then press PC power button a few times to drain the capacitors down before you go unplug and unplug stuff.
I have never heard of it happening. All stories of electrical damage I’ve heard of are instant. You should be fine, no need to worry.
Also, remember to quote (bottom left arrow) or tag (@username) to make sure people see your response.
PSU Tier List
SSD Tier List
PARROT GANG
8 minutes ago, VLumar said:
Should I continue to monitor the components? I've been checking up on them for an hour now as it runs.
No need to. If there were any issues, you would have noticed them by now.
PSU Tier List
SSD Tier List
PARROT GANG
