What cooler should I choose?
techrecorder
Hello! I want to get a cooler for my new i7-10700K.
I don't know if I should go for an AIO, or if I should go for air cooling.
whoosh tends to be safer (less to fail, still does something if fan dies) water may perform marginally better (multiple factors) recommend minimum 240mm aio or get a whoosh king
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Air cooling is just as affective as most AIO’s, and less failure modes/less spectacular failure if one occurred.
I would suggest the noctua ngc-d15 if you plan to overclock. If you go AIO, 240mm radiator at a minimum.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
Hello!
I have an i7-10700K and I found 2 AIO's that would fit nicely with my build.
Corsair H115i RGB Platinum and the NZXT Kraken x63 (both 280mm).
The NZXT one definitely looks better and more minimalistic in my opinion, but I don't know which one is better performance-wise.
Any opinions on this would be appreciated.
Thanks!
14 minutes ago, techrecorder said:
Hello!
Thanks!
https://www.gamersnexus.net/hwreviews/3457-corsair-h115i-rgb-platinum-cooler-review-asetek-vs-coolit
GamersNexus reviewed the H115i and in the benchmark it's present the X62, which it's basically the X63 with another maker for the pump
