Budget (including currency): $500
Country: Ireland
Games, programs or workloads that it will be used for: XCOM 2, Two Point Hospital, Sims 3, Sims 4, Minecraft, Battlefield 1, Kingdom Come, Apex Legend, PUBG, World of Warships, Stars Citizen, AOE DE
I have 2 PCs.
PC 1: Intel i5 4690K, MSI Z97 PC Mate, TX 750W, H60 AIO
PC 2: Intel i5 9600K, Asus ROG STRIX Z390 Gaming - F, Vengeance 3000MHz, H100i AIO, RMi 850W, Rocket Sabrent 1TB
I want to replace the 4690K because the TX 750W is almost dead. Actually I have already bought a CX 550W PSU.
Now I am hesitating between AMD and Intel and my budget is < $500 (Including the CX 550W which I had paid for $79).
I thought about a possible upgrade path in the future so between A520, B550 an X570, I am seriously considering B550 for the motherboard.
As for CPU, I have once set eyes on 3100 but after reading a few reviews I m more inclined towards 3300X given its comparatively more superior structure over the 3100.
These are the two components which I believe are the most crucial parts of the new build.
For cooling I either use the stock Stealth Air cooler or reuse my H60 AIO (I know it's dated and using it is silly but it's still functioning so why not)
As for RAMs, they are dropping in price so I guess I will get a stick of 2 16GB.
What you folks reckon about my plan?
Edited by AF101BG
hit the send key too early by accident.
https://linustechtips.com/topic/1239854-please-comment-my-build-plan/
Country: Ireland
I have 2 PCs.
MSI Z97 PC Mate
Whats your question? is its a new build for $500? also if you're in ireland, euros or GBP would be better
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
I think 32gb is kind of overkill for gaming. I’d suggest 16gb
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
33 minutes ago, AF101BG said:
Ok, point taken. But then say, if I can find a 32GB kit which is $10 or $15 more than a 16GB one, should I go for the 32GB one?
yes, but id be surprised if you could find one with similar speeds and timings for that difference. where are you buying from because you keep listing dollars? 3300X is only £120 but is out of stock at the moment. You could buy for that price and wait i guess.
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
