Can someone help me with my broken audio port
rocketbagel
My motherboard, the gigabyte z370 aorus gaming wifi rev 1.0, has an integrated sound processor and bundled software that would allow me to have a 5.1 surround setup if it works. However, one of the female 3.5mm audio ports just doesnt output properly. It is the C/sub port and all sound is extremely muffled and sounds like this. i have cleaned the port out once already with compressed air and it made no difference. I have tested the speakers and they all work fine, it is just the port. I really hope that this is a problem that i can fix myself. Thank you for your time!
The port: https://imgur.com/a/8nBRhE5
the mobo page: https://www.gigabyte.com/us/Motherboard/Z370-AORUS-GAMING-WIFI-rev-10/support#support-dl
Also i have to switch the sound software between headphone mode and 5.1 mode everytime i start up my pc for any audio to play...... but thats a problem for another day
We see 5 3.5 mm audio ports here.
Top right is an input for a microphone. Don't use it. Nothing should come out here.
Top center is stereo for both of your front speakers.
Bottom right is for your center speaker or subwoofer.
Bottom center is for both of your rear speakers (stereo).
Bottom left is just a headset output. Not for 5.1. Don't use it.
If you have a nice audio receiver it should have an optical input.
You could just get an optical cable and connect your motherboard's optical out to your audio receiver and you would have perfect 5.1 with just 1 cable.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
