Hi y'all,
I'm filling-out a digital form to get a replacement cable for the audio cable(regular headphone jack cable) of my headphones (B&O H9 3rd Gen). Mine doesn't have in-line controls, but the only replacement part on the producer's website is one with in-line controls which explicitly states it's for IOS. I have an Android phone so I was wondering whether the cable (or the in-line controls) would work on my phone (Samsung S10).
Kind regards,
LB
Edit: spelling is hard.
AMD Ryzen 5 3600X - Gigabyte B550i Aorus Pro AX - Gigabyte Windforce RTX 2070 Super - G.Skill Ripjaws V 32GB (2 x 16GB) DDR4 C16 @3600 MHz - ADATA XPG SX8200 Pro 1 TB - Corsair SF 600W 80+ Platinum - Cooler Master MasterBox NR200P White
https://linustechtips.com/topic/1238969-audio-cable-for-iosandroid-is-it-different/
It depends on the manufacturer, but generally for iOS-specific inline controls play/pause will work, but other media controls will not.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
9 minutes ago, Lord Blue of Screenshire said:
Hi y'all,
Kind regards,
LB
It might not work, Apple's 3.5 mm jack is different from android.
Test it with older air buds b4 ordering.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
The cable has arrived and this is true: pause/play works, but volume control doesn't. Is there a way around this?
Nope, this is a hardware limitation unfortunately. You can read more about this at https://forums.androidcentral.com/samsung-galaxy-s3/189523-final-soultion-why-most-headsets-wont-work.html.
Desktop
Homelab
