Hello guys! so i'hv been hearing some vibration noise on my pc and its coming from the psu area and some guys told me it can be the hdds causing the vibration against the case
it seems like the psu or the case are the problem
I run some tests i entred a game and took off the psu out of the case while its working and the noise stops okey lets not say stop but reduced a lot ( i was holding it on my hand ) and when i put it back to its place on the case the vibration comes again !
and lifting the case like 3mm or less stops the noise !
another thing i tried putting a peace of paper under the case's leg the one under the psu and vibration reduced alot maybe gone !
So i wanna know if its a case problem or a psu itself ? and is  that vibration can harm the psu in the future ? ( not sure its the reason or the case )
https://linustechtips.com/topic/1238701-case-or-psu-vibration-problem/
The vibration itself won't harm the PSU. The source of the vibration might be a sign of problems though. Most noteably, a bad or unbalanced fan inside your PSU.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Some foam or rubber pads should be pretty cheap
Primary PC:
PSU tier list
How many watts do I need?
Considering the paper thing, Maybe your psu is vibrating slightly not making much noise, but moving the case, then when your case is moving that is actually creating the vibrations itself? Can you not leave a piece of paper under the cases leg permanently? Maybe cut it out the exact size, or perhaps even a piece of fabric like felt?
It's also possible that if you have a really cheapy constructed case, those vibrations are amplified by the ill-fitted pannels rattling.
are u sure it's not a case problem ? making it vibrate ? because as i said when I took it off the vibrates stops and I remember using an old psu also the vibration was there
and why touching it or lifting it a bit make it stop ?
I mean, i just tried picking my case up (Corsair 500D SE) and it makes it a lot quieter (so i may also get some sort of pads now), but thats deffinitely not a cheap case, so probably not so much that its cheap, but possibly a design flaw.
Oh I've seen really cheap cases where it's basically made of tin foil. Like cases where the structural integrity comes from mounting the motherboard and drives in it.
Because you are absorbing the vibration with your hands.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
16 minutes ago, The Torrent said:
Considering the paper thing, Maybe your psu is vibrating slightly not making much noise, but moving the case, then when your case is moving that is actually creating the vibrations itself? Maybe cut it out the exact size, or perhaps even a piece of fabric like felt?
yes i guess because my case is cheap one !  and also another thing i had an old pus and the vibration was also there !
yes i guess thats my only choice
u saying the rubber pads can be the reason ? because i have a cheap case
Yeah if you buy some cheap furniture pads or something, it should be pretty easy to get rid of the noise. Maybe you need to make them skinny by cutting them in half, but otherwise it sounds like a convenient fix.
Primary PC:
PSU tier list
and you think that vibration can be harmful ?
No but if it's annoying you should fix it
Primary PC:
PSU tier list
