I replaced the cpu in my optiplex 3020 from a known good i5-4570 to an unknown i7-4790 from a friend.  It wouldn't boot, but all the fans came on and the hard drive and disk drive spun up.  when I switched back, it still wouldn't boot, same symptoms.  I realized that I didn't update the bios after some googling, but now it wont boot so I can't.  My motherboard is probably dead at this point, right?
1x2gb ram
1x4gb ram
seagate hard drive (500gb or 250, I have two)
igpu
255w power supply
The 4790 is devil's canyon, a special release after 4th gen which had boosted clocks and improved thermal interface.
However, I bet that optiplex doesn't support devil's canyon, so you should look up the support list. You're likely only able to get a 4770 in that bad boy.
As for not able to boot, you need to clear the cmos. You can unplug the PC and remove the cmos battery on the motherboard to do that, and leave it for a minute.
Primary PC:
PSU tier list
How many watts do I need?
6 minutes ago, SmoothJazz321 said:
I cleared the cmos and reseated the ram and that fixed it.  how do I mark the thread as solved?
Hit that check mark.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
