Budget? Workload? The board is crap and so is the PSU.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1237348-building-a-pc/#findComment-13947519
10 hours ago, Olivier Hijlkema said:
How could I change it?
would go with a pure power 11, but it's currently out of stock.
Build Log:
https://linustechtips.com/topic/1237348-building-a-pc/#findComment-13947532
6 minutes ago, TofuHaroto said:
I already ordered my gpu and ram and case
https://linustechtips.com/topic/1237348-building-a-pc/#findComment-13947546
then get the board, drive and the and the psu..
Build Log:
https://linustechtips.com/topic/1237348-building-a-pc/#findComment-13947550
This motherboard is in stock can I use this one?
still a horrendous board. the pro 4 is good.
Build Log:
https://linustechtips.com/topic/1237348-building-a-pc/#findComment-13947578
that is even worse. mayby asrock b450 pro 4? should be around the same price point
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1237348-building-a-pc/#findComment-13947580
