Top mounted psu
Go to solution Solved by none77,
When the PSU top mounted with fan down it take air from the case and throw it out, with your setup it's looks reasonable because it don't expect to produce a lot of heat, if you wan't the amount of hot air in the PSU you should have at least one fan in the rear or top, you can put the fan up and drill holes in the case that air will enter from top, outside the case.
Hi.i need help. I have an old pc case that the psu is mounted on top.The question is can i use it on my new pc build? Is that dangerous?cause im not a person that wants a fancy rgb thing. I just want the performance and reliability of my pc.And my second crazy question is does my psu will fall ? Because its on top?? 馃槗馃槗
https://linustechtips.com/topic/1236897-top-mounted-psu/
What psu do you have (wattage, what name, does have 8 pin 4 pin or 6 pin)
https://linustechtips.com/topic/1236897-top-mounted-psu/#findComment-13943951
18 minutes ago, Wojtek16 said:
It won't fall. I have PSU mounted on 2 screws in my PC and it works doesn't even move
The only thing why i say will it fall is because my psu is kinda not straight. But its straight.Its just that its kinda not perfect straight because only the left side where the screws has a 2joint on the bottom.or is it normal ?. Sorry im noob on this pc world
https://linustechtips.com/topic/1236897-top-mounted-psu/#findComment-13943981
https://linustechtips.com/topic/1236897-top-mounted-psu/#findComment-13944606
