My GPU has Zero RPM on so it runs without fans for a few minutes at idle, then suddenly turns the fans on super high for a few seconds and turns them back off again.  It is insanely annoying, I can hear it from multiple rooms away even with the TV on.  Radeon software has a setting for zero RPM, and i have tried turning it off, applying changes, and saving the profile.  I walk away and hear it making the awful an noise again.  I am super stumped, but i am not sure i can take this noise much longer.
My build
Ryzen 5 2600 @3.95ghz
Cryorig M9a
Gigabyte x470 Ultra Gaming
Gigabyte RX 590 @1720mhz
2x8 Corsair LPX Vengeance 2933
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
WD Blue SATA SSD 500GB
https://linustechtips.com/topic/1236656-zero-rpm-problems/
It's probably engaging the fans once it reaches a temperature set by the manufacturer but once it gets to it it cools down only for it to get to that temperature again in some time
But it shouldn't engage at max RPM usually they start from 1000RPM and ramp it up accordingly to temperature and they are silent
A friend of mine solved by setting it to low speed with MSI Afterburner when he isn't using it for gaming or heavy workload
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13941868
Aight, I am gonna try something.
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13941879
Just set a custom fan curve in Afterburner like @Jenko32 said.
Have something like this:
Keep it at a low rmp till you want the card to ramp up.
Don't copy mine, since it's for a 390 and they run pretty toasty
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13941885
lol the space heater card.
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13941890
It will reach 75ish c even at full 100% fan speed, sometimes it gets near the 80s. With the stock fan curve I was in the low 90s
At least is not that loud lol
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13941897
lol.  some 390s are loud.  like jet engine loud.
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13941899
my gtx 1070 had the same problem was never able to fix it. But the fans where also terrible. so, i decided to remove the fans/shroud and zip tie 2 x 120mm fans to the gpu heatsink. You can connect standard fan to the gpu header with an adapter, but i just connected the fans to the motherboard and offset the curve for the header. i love it. way better temps, way less noise, and way better OC now.
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13942494
thats actually a pretty good idea.  thx
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13942905
1 minute ago, narrdarr said:
If you do it right you can make it look really good too. got questions, just let me know
ive been thinking of ghetto cooling solutions for it for a while.  Here are some of them.
CPU cooler on GPU
CPU water cooler on GPU
Aftermarket GPU cooler
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13942932
27 minutes ago, rx590overclocker said:
CPU cooler on GPU
it works well, but the downside can be big. they take a lot of space. Mounting can be challenging  not so much attaching, but making sure certain things are not touched by the cooler and mounting pressure. To loose = bad performance to tight = cracking the die(gpu has not heat spreads like the cpu does). weight. mosfets and vram cooling could be better depending on the cooler used and if there is added heatsinks for the mosfets and vram
they actually make attachment to use an aio on gpu's. the G12 is one the better ones. it works well but depending on the may need to mod the attachment and run into the same issue with vram and mosfet cooling
there are several, but the best ones that i know of are the Accelero and the morpheus. morphues does come with heatsinks for the vram and mosfets, but the are good if you choose it i wouldn'e even use them, but the cooler is massive and designed to use 120mm.
personal do to lack of cooling vram and mosfets with other cooling and cost, is why i decided to zip tie 120's to the stock cooler.
https://linustechtips.com/topic/1236656-zero-rpm-problems/#findComment-13943013
