You could bump up the voltage for both the dram and frequency and check what timings you can get and at what frequencies.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1236373-memory-timings-help/#findComment-13939711
my memory is oc'd to 3600 .. the default is 3200 16-18-18-38 with 1.35
im running my 3600 with 1.4v
https://linustechtips.com/topic/1236373-memory-timings-help/#findComment-13939718
Then you could check how tight you can get the timings and at what frequencies.
Also try setting the vccio and sa voltages to something like 1.2/.1 and check.
As to how tight you can get the timings to.
We don't really know, every kit has different capabilities and it depends on more than one thing.
Build Log:
https://linustechtips.com/topic/1236373-memory-timings-help/#findComment-13939721
