Weird GPU fan problem?
Solved by CWALD,
7 minutes ago, Imrandaredevil said:Thanks for the reply! I made a thorough research with the "PSU CLICK" both old and new forum users report that the sound comes from the "relay switch" which is normal and that some PSU models do make that noise. What's weird is the fan spin... really odd. However, your reply should be the answer I am looking for.
No problem, It does sound like a relay in the vid, I just hadn't heard it in a PSU before. If you have another PSU in another system on hand then swapping it would be an easy way to verify.
