Hello,
I have a old 1050 TI from a prebuilt. I think the fan header on the card is broken because the GPU fan doesn't spin even when I set it to spin to max. I cannot replace the card as it is in a small form factor prebuilt from LENOVO. The PC is out of warranty and I cannot find a replacement anywhere. I have tried plugging the 2 pin connector from the 1050ti's fan into the 4 pin connector on my main PC and the fan spins fine. Is there any way I can fix the fan header or anywhere else I can plug the fan into if the mobo on the PC doesn't have any fan headers? Thanks. The PC is a Lenovo ideacentre 660s by the way.
https://linustechtips.com/topic/1236176-gpu-fan-header-not-working/
