I have a gtx 1650 oc with amd 3500x new build. Every time i try to stream using obs. GPU core clock locks at 300mhz normally i would get 1400mhz+. I already checked any available solution through the net but failed to resolve this issue. Anyone had experience this? Even if i am not doing anything on my computer. It says perfcap reason "Power". Any idea how to fix this
https://linustechtips.com/topic/1236168-gpu-limited-by-power/
Did you plug in the power connector from the PSU into the GPU? Check to make sure that is connected properly and completely. Try another PCI-e power connector from the PSU.
If none of that changes anything, or you don't have a power connector on that GPU, then you may be out of luck.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1236168-gpu-limited-by-power/#findComment-13938760
