Passive Cooling on metal surface equipment
18 minutes ago, TigerBoy said:It is the heatsink mainly. It would definitely benefit to put two smaller fans inside to push the hot air out instead. I know for gear like these it is mainly intakes due to the even dimensions of the chassis. Is there any benefit doing a push pull with 40mms or is it better to go push push for the two 40 mms to also cool the power components? (or maybe experiment and go from there)
May just hold off on switch B for now as the border is not allowing imports. My problem now is switch A... Found a picture of it open. It is quite small which makes fan cooling impractical. This one goes around the 60 degree range without load which is too hot. Do you think it would benefit from sticking a heatsink on the chassis? I am not too sure how thick of pads I need for this... thinking 1mm or .5mm is ideal as the heat is not too intense. What do you think?
As for the fans, you will have to experiment, so try everything it seems logical to you. If you experiment remember to use it in the same scenario, like transferring a big file back and forth many times
As for the thermal pads, the more there are in between the less efficient it will be, as it's really difficult to calculate I guess that you can only try and see, we have to remember that not only you would need a thermal pad inside between the heatsink and the chassis but even between the external heatsink and the chassis. and let's not forget that the chip itself as some kind of thermal interface to the black internal heatsink, it would be a complex system to calculate the variables and only if you try it you will see if there are benefits. You would need to make holes (or use some kind of clamp?) for the external heatsink to compress the thermal pad and make good contact
If it's something you want to put effort in, you could create a wood/plastic taller case for it with a hole for a fan on the top and many mini holes as side vents to exhaust the heat.
Or put it in a box where it fit and make the mini holes to emulate side vents and put a fan there
