Posted August 18, 2020 Components: Super Flower Leadex iii 750w 80+ Gold PSU (Fan mounted blowing downwards), Gigabyte Aorus Elite X570 Motherboard, AMD Ryzen 9 3900x 12 Core 24 Thread W/ Wraith Prism, 4x8GB 3200 Mhz C16 G Skill Royal, Samsung 970 Evo + 500 GB NVME, 2 TB Barracuda HDD, MSI Gaming X 2070 Super. Corsair: 220T Airflow Icue RGB case, 2 JBtek Black Braided fan splitters, 2 SP120 RGB Pro fans mounted for exhaust. K95 Platinum XT Keyboard. Nightsword RGB Mouse. Peripherals: AOC CU34G2X 3440x1440p 144hz 1ms Monitor, Elecrow 10.1 inch 1080P 60hz IPS Raspberry Pi Monitor (HDMI/VGA), Astro A40 TR W/ Mixamp Pro, Sudotack ST-800 USB Condenser Microphone, Xbox One Elite Series V2 Controller, Unzano 1080p 60 FPS Webcam, Bluetooth Adapter. Additional Specs: Windows 10 64 bit, Ryzen Master Precision Boost Overdrive W/ Max of 4.6 Ghz, MSI Afterburner 2070 Super Overclock to 2020mhz Core 8000mhz Memory. Temperatures During MW Warzone: CPU Max 65 Celsius @ 4.2Ghz GPU Max 65 Celsius @ 2020mhz / 8000 Mhz Cinebench Score: 3. 12C/24T @ 3.8GHz, AMD Ryzen 9 3900x 12-Core Processor: 6774 FPS Benchmarks: Doom Eternal: 144FPS: Ultra Nightmare, Motion Blur off Modern Warfare: 120FPS: (Geforce Experience Optimized) Death Stranding: 120FPS: Ultra, DLSS 2.0 Quality (Geforce Experience Optimized) Fallout 4: 144 FPS: Ultra ( Geforce Experience Optimized) Ergonomics: Casaottima L Shaped Desk, Staples Carder Mesh Back Ergonomic Chair W/ Tilt, Height, Lumbar Adjustments. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 2 minutes ago, SaiyanPaths said: 3. 12C/24T @ 3.8GHz, AMD Ryzen 9 3900x 12-Core Processor: 6774 Think you over spent on the CPU if you don't need the cores but besides that it's fine. Also the RGB is making my eyes bleed and I absolutely love it. I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies. PSU Teir List | Howdy! A Windows Hello Alternative Desktop : i7 8700 | Quadro P4000 8GB | 64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo Laptop : ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934769 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 4 minutes ago, SaiyanPaths said: 12C/24T @ 3.8GHz, AMD Ryzen 9 3900x 12-Core Processor: 6774 this is with PBO? cinebench R20? edit: oh stock cooler, move along rainbow build tho, noice -sigh- feeling like I'm being too negative lately Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934771 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 Author @Moonzy Yes this is with PBO in Creator Mode, and yes Cinebench R20. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934778 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 1 minute ago, SaiyanPaths said: Yes this is with PBO in Creator Mode, and yes Cinebench R20 that's lower than my undervolted 3900x i suggest looking into undervolting as you might be hitting thermal limit with PBO during full loads might be able to get higher multithreaded perf out of it though my single thread perf prob much lower since my max freq is 4.0 -sigh- feeling like I'm being too negative lately Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934791 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 Author 1 minute ago, Moonzy said: that's lower than my undervolted 3900x i suggest looking into undervolting as you might be hitting thermal limit with PBO during full loads might be able to get higher multithreaded perf out of it though my single thread perf prob much lower since my max freq is 4.0 Thank you for the input! I am still completely new to overclocking, and even building my own PC, I Just figured PBO was the best option for me. Its confusing because during Warzone it runs sready at about 4.2ghz and never goes above 65 degrees. Maybe I need to read more but I don't want to go outside of the auto overclocking sue to having a stock cooler. IDK about going into manual OC mode. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934809 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 Author 1 minute ago, SaiyanPaths said: Thank you for the input! I am still completely new to overclocking, and even building my own PC, I Just figured PBO was the best option for me. Its confusing because during Warzone it runs sready at about 4.2ghz and never goes above 65 degrees. Maybe I need to read more but I don't want to go outside of the auto overclocking sue to having a stock cooler. IDK about going into manual OC mode. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934826 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 11 minutes ago, SaiyanPaths said: I Just figured PBO was the best option for me if you game, PBO is great because it push single thread performance to the limit 11 minutes ago, SaiyanPaths said: during Warzone it runs sready at about 4.2ghz and never goes above 65 degrees yea you wont run into thermal issues unless you load all 12 cores at 100% the stock cooler handles gaming load just fine how hot is the CPU during cinebench though? curious how does wraith prism perform on the 3900x here's mine Spoiler score is 6827, 3900x at 1.1v 4.0 on CCD 0, 3.8-3.9 on CCD 1 cooler is dark rock pro 3 though, so it runs cooler but still runs at 80c on stock voltage and settings -sigh- feeling like I'm being too negative lately Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934834 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 Author 5 minutes ago, Moonzy said: if you game, PBO is great because it push single thread performance to the limit yea you wont run into thermal issues unless you load all 12 cores at 100% the stock cooler handles gaming load just fine how hot is the CPU during cinebench though? curious how does wraith prism perform on the 3900x here's mine Reveal hidden contents score is 6827, 3900x at 1.1v 4.0 on CCD 0, 3.8-3.9 on CCD 1 cooler is dark rock pro 3 though, so it runs cooler but still runs at 85c on stock voltage and settings Max temp during Cinebench. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934849 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 1 minute ago, SaiyanPaths said: Max temp during Cinebench. 80c as well, interesting you should be good -sigh- feeling like I'm being too negative lately Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934856 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 36 minutes ago, SaiyanPaths said: Elecrow 10.1 inch 1080P 60hz IPS How do you find the quality (sharpness, brightness, colour clarity etc) of this monitor? NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934873 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 Author 4 minutes ago, Radium_Angel said: How do you find the quality (sharpness, brightness, colour clarity etc) of this monitor? https://www.elecrow.com/10-1-inch-1920x1080-resolution-hdmi-vga-ips-ps3-ps4-gaming-screen-with-build-in-speakers-for-raspberry-pi-b-2b-3b-xbox-windows-7-8-10.html Features 1920X1080 resolution, up to 1080p with clear image and colorful display. IPS LED Technology Display brings you a subversive color experience and large viewing screen. Support audio speaker with built-in high-quality loudspeakers. 10.1 inch Screen Size - portable display monitor much more easily to take it to anywhere you like. Compatible for PS3 PS4 XBOX360 Raspberry pi, industrial equipment, car audio and video,car headrest, medical equipment display. Specifications Model: SF101 Display Technology: LED Display Screen Size: 10.1 inches Aspect ratio: 16: 9 (width: height) Panel brightness: 350cd / m² Contrast: 800: 1 (Min) (transmission) Resolution: 1920X1080, up to 1080p Viewing angle: 170 degrees wide viewing angle Appearance size: 255mm x 164mmX28mm Working environment temperature: -30℃--+50℃ Display mode: Constant black display, transmission type Display color: 262K/16.7M (6-bit/6-bit+Hi-FRC) Response time: 13/12 (TYP) (Tr/Td) (ms) Screw thread size: M3 Pitch of the VESA mount holes: 75mm*75mm Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934892 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 10 minutes ago, SaiyanPaths said: https://www.elecrow.com/10-1-inch-1920x1080-resolution-hdmi-vga-ips-ps3-ps4-gaming-screen-with-build-in-speakers-for-raspberry-pi-b-2b-3b-xbox-windows-7-8-10.html Features 1920X1080 resolution, up to 1080p with clear image and colorful display. IPS LED Technology Display brings you a subversive color experience and large viewing screen. Support audio speaker with built-in high-quality loudspeakers. 10.1 inch Screen Size - portable display monitor much more easily to take it to anywhere you like. Compatible for PS3 PS4 XBOX360 Raspberry pi, industrial equipment, car audio and video,car headrest, medical equipment display. Specifications Model: SF101 Display Technology: LED Display Screen Size: 10.1 inches Aspect ratio: 16: 9 (width: height) Panel brightness: 350cd / m² Contrast: 800: 1 (Min) (transmission) Resolution: 1920X1080, up to 1080p Viewing angle: 170 degrees wide viewing angle Appearance size: 255mm x 164mmX28mm Working environment temperature: -30℃--+50℃ Display mode: Constant black display, transmission type Display color: 262K/16.7M (6-bit/6-bit+Hi-FRC) Response time: 13/12 (TYP) (Tr/Td) (ms) Screw thread size: M3 Pitch of the VESA mount holes: 75mm*75mm What I meant was, do *you* like it? Are you satisfied with the quality of the display? NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934941 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2020 Author 4 minutes ago, Radium_Angel said: What I meant was, do *you* like it? Are you satisfied with the quality of the display? Oh haha sorry, I love it! it functions perfectly for what I use it for, which right now is an extra window for temperature readouts and to watch twitch while I game. I also intend to use it for streamlabs, I may actually buy a second one because it fits perfectly under my monitor. I did have to increase text size to 125%. Link to comment https://linustechtips.com/topic/1235812-my-first-pc-build/#findComment-13934982 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
