Hi everyone,
i need some help deciding on a pc upgrade. i'm currently running an old budget gaming pc:
i3 6100
1060 3GB
128GB SSD
2TB HD
500w PSU
G1.SNIPER B150 MOBO
16GB RAM
i have a little money to spend. Am i being heavily bottlenecked by my CPU? Is a 1660 super a good option? is a ssecond hand i5 7600 worth?
Thanks for any help
https://linustechtips.com/topic/1235602-upgrade-help/
NO. The cpu is perfecly fine with 1060.
You should get a second hand i7, upgrading to i5 won't make any difference.
https://linustechtips.com/topic/1235602-upgrade-help/#findComment-13932648
18 minutes ago, Hugh_Jassole said:
or is there a more appropriate GPU I could get? I'm happy to buy second or brand new.
This is a good PC for now. I would wait till the new stuff is out, I'm willing to bet the RTX 3060 will ship around November 1 for Cyberpunk. It may even have a download code for free, they did that for Witcher 3 and they're partnering with Nvidia for development and launch anyway.
Several Ryzen 4000 CPUs should be out around then as well.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1235602-upgrade-help/#findComment-13934188
