Budget (including currency): $300
Country: United States
Games, programs or workloads that it will be used for: Streamlabs OBS/Chatbot, Warzone, GTA V, Fall Guys, StarCraft II, Movavi Video Editor, GIMP/Paint.net
Current Build:
DELL Optiplex 990 case
DELL proprietary 265W power supply
Unknown DELL LGA 1155 motherboard (4 DIMM slots, Gigabit Ethernet port, NO WiFi/BT or M.2/nVMe slots)
Intel i5-2400
NVIDIA GTX 1050 (non-Ti) 2GB
8 GB RAM
1.70 TB total storage (1 TB SanDisk Sata SSD, 240 GB Boot Sata SSD, 500 GB HDD)
Hi! First post on here, thanks for having me! I was mainly wanting to know where to start on upgrading my rig, or if it's realistically viable to. I realize when upgrading anything will probably require the board, CPU and power supply to be also upgraded, this is moreso to ask what is a good upgrading route like where to start first and what can wait (I'm sure that PSU will be the first thing haha), or if I'm better off waiting a little while longer and just start buying parts for a new machine altogether.
I want the machine to be able to do video recording/editing, photo editing, and can be up there in game performance. Don't need it to look AMAZING, just want it to be able to look decent while running well. If I have one specific game I'd like to play, it'd be NBA 2k so I have more of a reason to completely switch to PC from console
I'm looking to stay with NVIDIA for GPU, either some sort of higher-tier Intel that supports LGA 1155 (it's rare, I know lol) or to completely switch to AMD if I have to replace the motherboard, and a PSU I won't worry about upgrading for at least a few years.
Any help would be appreciated!
"... Clouds?"
Hank Hill
Build 1 (Current, built myself): CPU - Ryzen 7 2700 w/ Wrath Spire Mobo - GIGABYTE GA-A320M-S2H RAM - XPG GAMMIX D30 16GB (2x8GB) DDR4 3000 Storage - 1TB Samsung 970 Evo Plus NVMe (Boot), 1TB SanDisk SATA SSD, 500GB Western Digital HDD GPU - GTX 980 Ti 6GB PSU - EVGA 600W 80+ Certified Case - Thermaltake V100 w/ 4 case fans (RaidMax Red LED 120mm back exhaust, Thermaltake 120mm top front exhaust, Zalman Blue LED 120mm front top intake, Kingwin 140mm front center intake)
Build 2 (Secondary, bought prebuild and upgraded): CPU - i5 2400 w/ stock cooler Mobo - proprietary Dell Optiplex 990 motherboard RAM - Samsung 8GB (4x2GB) DDR3 1333 Storage - Samsung 240GB SSD (Boot), Samsung 1TB HDD GPU - GTX 1050 Ti 4GB PSU - proprietary Dell 265W Case - Dell Optiplex 990
https://linustechtips.com/topic/1235527-good-upgrades-for-current-build/
imo sell the main parts of what youve got, you can easily get 150 at least. then stick your storage into a build like this:
if you can find a good deal on a cheap case locally or something that'd be a good way to save a few bucks.
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
1 hour ago, VeganJoy said:
    $534.85
  Generated by PCPartPicker 2020-08-17 14:16 EDT-0400
Thats way over budget.
The best CPU you could fit in that motherboard would be an i7 3770 which I would recommend to buy used it you do. Assuming you have extra DIMM slots, you could add another 8 to make 16GB ram. And then you could upgrade your GPU to something like a 1660 super.
That is one option. or you're probably better off building a whole new system. There is not much you can build with $300 but you can use your current storage and possibly your case
op said:
which is likely the best idea here; a 3770 runs about 70 bucks used, another 8 gb of ddr3 is ~20-30, and a 1650 low profile would be 140-150. might as well sell the current build, the 1050 is worth almost 100, the rest of it can go for another 100. that frees them up for a new build on a modern platform with better performance and a strong upgrade path for the next few years. finding some deals on the used market can help stretch out their current budget along with profits from selling what they've got, or they can save a bit for new parts.
