Budget (including currency): 15.000.000 IDR
Country: Indonesia
Games, programs or workloads that it will be used for: Visual Studio, SQL Server, Weird Japanese Game I am not familiar is,
Other details : I'll Link Enterkomputer (kind of like Memory express/Micro center equivalent on Indonesia store build page as reference)
Dear LTT forum resident
I am currently building part for my little brother PC, dad ask me to setup some part for his PC
he is CS (Computer Science) Student, we were considering 10600k but we cannot find Prime Z490-A board, other board price is way too expensive and jack the price up, and simillar price board is just very bad on review
so here is the build part I have setup, kindly suggest if there is any input from you guys, regarding the spesific model that we going to use, and please inform us if there is any product that is bad or we should avoid from this list
Kindly use Link https://www.enterkomputer.com/simulasi for simulation build to see if your suggested part is available on indonesia region :)
Current Build Link
https://www.enterkomputer.com/simulasi/preview/5Hrkc8hm
1   PROCESSOR
AMD Ryzen 5 3600 3.6Ghz Up To 4.2Ghz Cache 32MB 65W AM4 [Box] - 6 Core - 100-100000031BOX - With AMD Wraith Stealth Cooler Ready Stock
1 Rp 2.941.000
2   HARDDISK
WDC 2TB SATA3 256MB - Blue - WD20EZAZ - Garansi 2 Th Ready Stock
1 Rp 901.000
3   SSD **
WDC Black PC SSD 250GB M.2 NVMe PCIe
1 Rp 919.000
4   VGA **
MSI GeForce GTX 1650 SUPER 4GB DDR6 - Ventus XS OC
1 Rp 2.911.000
5   PSU **
Seasonic M12II-620 Evo Edition 620W Full Modular - 80+ Bronze Certified - 5 Years Warranty Replacement - Retail Box (NO OEM)
1 Rp 1.190.000
6   RAM
ADATA DDR4 XPG SPECTRIX D41 GREY PC24000 3000MHz 16GB (2X8GB) Dual Channel - RGB Ready Stock
1 Rp 1.190.000
7   MOTHERBOARD
MSI B450 Tomahawk MAX (AM4, AMD Promontory B450, DDR4, USB3.2, SATA3) Ready Stock
1 Rp 1.980.000
8   MONITOR
LG 22" LED 22MK600 - IPS Panel Ready Stock
1 Rp 1.499.000
9   CASING **
Corsair Carbide 275R (White)
1 Rp 1.180.000
10   KEYBOARD
Logitech Classic keyboard K120 Black USB Ready Stock
1 Rp 110.000
        Grand Total : Rp 14.821.000
https://linustechtips.com/topic/1235110-cs-student-build/
are you only limited to enter komputer? you can have more if you are open to other vendors
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1235110-cs-student-build/#findComment-13928231
26 minutes ago, heickelrrx said:
with out current leftover budget we can afford 5500XT 4GB, or RX 570 8GB, 1650 super is the maximum nvidia card we can afford
Get a non or semi modular PSU and try to get a better GPU, Nvidia ones have better drivers.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1235110-cs-student-build/#findComment-13928241
1 minute ago, heickelrrx said:
this just as baseline, most of the price is similar right
most of the time yes, are you ok with tokopedia links? i will see what i can do, but will need the time
also do you need cuda?
Edited by Oswin
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1235110-cs-student-build/#findComment-13928248
sorry for the late reply this is what i have came up with
CPU: AMD Ryzen 5 3600 6-Core 3.6GHz
Motherboard MSI B450M Gaming Plus
RAM: Team Delta TUF DDR4 RGB PC25600 3200Mhz Dual Channel 16GB (2x8GB)Black
GPU: VGA SAPPHIRE - PULSE RX 5600 XT BE 6G GDDR6 / RX 5600XT BE 6GB GDDR6
Storage:
ADATA SSD XPG SX8200 PRO M.2 Pcie Gen3 Nvme 512GB - 3D Nand 512 GB
WD Blue PC 2TB 3.5" HDD/ HD/ Hardisk/ Harddisk Internal
PSU: CORSAIR CX550 80+ BRONZE - CX550W 80+ BRONZE
Case: Tecware Forge M Tempered Glass / Casing PC
Total price: Rp13.752.000
left some for the monitor and peripherals so that you may decide what you need
Edited by Oswin
updated links and list
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1235110-cs-student-build/#findComment-13928347
