If you can't return it, get a locked i7-8700 and call it a day.
It will perform just as good as anything AMD has at gaming and will work on the b365
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1234956-need-a-cpu/#findComment-13927210
13 minutes ago, Swiftblade131 said:
I have recently bought a MSi B365M PRO-VH Micro ATX motherboard.
I'm very confused as to why you would buy a motherboard without taking into account the CPU.
Either way, a 9600k would pair well.
14 minutes ago, Swiftblade131 said:
I have a GTX 960 and I might upgrade to a 970.
What. Why?
ask me about my homelab
https://linustechtips.com/topic/1234956-need-a-cpu/#findComment-13927213
