PC freezing after a few minutes of use
Solved by LogicalDrm,
EDIT: I just found out that both my sticks are running at 800MHz, they should be running at 1600MHz. Should I "overclock" them?
They are DDR memory as in Double Data Rate. So if you see them running 800MHz in CPU-Z etc means that they run at correct speed.
As for your problem. I think you have bad HDD. Can you try with another one or RMA your current`?
Featured Topics
Davidf4e ·
Posted in Troubleshooting0 -
Sychicyuto ·
Posted in General Discussion3 -
2
Bobzcpu ·
Posted in Power Supplies2 -
2
RZBAKA ·
Posted in New Builds and Planning8 -
1
Magnumenforce ·
Posted in Phones and Tablets2 -
1
