LAN File transfering speed too slow, 10 MB/s or slower
Solved by RageTester,
If it's slow with different cable it's most likely some software issue...
1) Update your network drivers. Also make sure you network card is set to full duplex and not half duplex.
http://www.home-network-help.com/speed-and-duplex.html
DO NOT use 'Auto' as that may negotiate you to half duplex and limit your speed to ~10Mbit/sec
2) Go to the Ethernet controller in Device Manager, and under Advanced, disable "Large Send Offload".
