https://linustechtips.com/topic/1233430-coolant-compatabililty/
https://linustechtips.com/topic/1233430-coolant-compatabililty/#findComment-13914965
7 hours ago, LackWiz said:
Well years hopefully. At least till whatever rtx/GTX 4000 series something comes out in 2023
Okay, well straight out of the gate the aurora booster effect will last you a couple of weeks tops (more like 1 week). It then proceeds to clog the system so I would not recommend it in any non-show build (i.e. meant to only run for the duration of a trade convention)
There UV clear blud dye and the pastel v2 should be compatible, but the Pastel is already UV reactive so not sure if you benefit and/or need to add more to it. This under the right circumstances should hold up at least a year, usually more. Though I would still recommend yearly changes.
https://linustechtips.com/topic/1233430-coolant-compatabililty/#findComment-13919257
