Hi, I have a MacBook with two thunderbolt 3. And I need to connect to it the charger, my monitor, one external ssd and sometimes my iPad or something like that, and everything use usb c. So, is super easy find an usb type a hub. But I never find something that give me a bunch of usb c from usb c. I need more usb C, not A. Somebody know something could help me? From Amazon because #mexico. Thanks in advance o/
https://linustechtips.com/topic/1231746-thunderbolt-hub/
You could get a monitor that accepts display over USB-C and can also do power delivery. At work we use this one: https://store.hp.com/us/en/pdp/hp-z27-27-inch-4k-uhd-display
This means you need only one USB-C port for both monitor + charging. The monitor itself has multiple USB-ports including one USB-C port. So when the monitor is attached you still have 2x USB-C and 3x USB-A.
You may be able to find a cheaper models with similar features.
~edit: Here's a simple hub: Sitecom CN-386
https://linustechtips.com/topic/1231746-thunderbolt-hub/#findComment-13900685
I already have a monitor, yes without power delivery, but I don’t want a new monitor, I was thinking in something more cheap, I just need a few more usb c ports
https://linustechtips.com/topic/1231746-thunderbolt-hub/#findComment-13900795
Yeah, I understand. Just saying it's an option. The link I added at the end is a simple USB-hub that has power delivery and three additional USB-C ports.
https://www.sitecom.com/usb-c-hub-4-port/cn-386/p/1881
https://www.sitecom.com/en/usb-c-hub-4-port/cn-385/p/1879
They're also available on Amazon as far as I can see.
https://linustechtips.com/topic/1231746-thunderbolt-hub/#findComment-13901776
i see, ok that was helpful dude, thanks
https://linustechtips.com/topic/1231746-thunderbolt-hub/#findComment-13902116
