Now, here's the deal. I've got a MB and a CPU, and don't know which one of em is broken, cuz when I tried to boot, only the fans started spinning but nothing else happened. A while ago, I accidentally ripped the cpu out of the socket (pga, amd a10 7860k) no pins were bent or broke. So I thought it would be fine. I got an other used motherboard and now I got a screen, which only said the name of the bios. it seemed like it tried to boot, but then it got in a bootloop. Now I got an internal speaker, and it said a short beep, indicating, that everything's fine. Now I have literally no idea what's going on. The MB: Gigabyte F2a88x-d3h
I already tried clearing the cmos, but it didn't help. The rest of the components of the pc work perfect. Any help?
https://linustechtips.com/topic/1231221-weird-issue/
1 hour ago, Biomecanoid said:
PC sound fine, try to install windows, boot of USB or DVD to install windows or try a Live Linux distro to see if it works
No, actually the pc is not fine. I used my ssd with windows, that still works, I use it everyday. With it plugged in, it doesn't boot either. Like I said, it bootloops. And I don't even get into accessing the bios.
https://linustechtips.com/topic/1231221-weird-issue/#findComment-13896530
