Mobo usb header question.
Go to solution Solved by Guest,
1 minute ago, Tume said:
Thanks, I'm really confused with the usb stuff :D The naming and all. Also one more question for shits and giggles. Are the rear usb ports directly connected to motherboard, I'm not 100% sure about this either but think so
yes
Hi,
First post here.
So my question is if i plug a front usb 2.0 cable to it's header will the 3.0 front ports in the case work? Like at all or with the 2.0 speed or do i have to use 3.0 cable and plug that to it's header to get the ports to work? Just curious. No real problems here.
https://linustechtips.com/topic/1230996-mobo-usb-header-question/
yes
