This is my second time building a computer, the first time was three years ago and everything went smoothly, this time tho im not getting a post. Every video i watched along with the troubleshooting steps has brought me no closer to a solution, and im in a bit of a pickle, would really appreciate some help
System:
AMD Ryzen 7 3700x + coolermaster cpu cooler
G.Skill Trident Z RGB 3200MHz 16GB
MSI B550 Tomahawk
Sapphire RX 5700xt
TX650M Corsair psu
Kingston A2000 250GB NVMe M.2 SSD
Thats whats currently plugged inn, everything powers on, but i still get no post
Any help is appriciated
https://linustechtips.com/topic/1229976-no-post/
You need RAM to post.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1229976-no-post/#findComment-13886011
1 minute ago, Aricu said:
I forgot to mention it, everything is going quite quickly, and im a bit sick
Does anything happen when you power it on? Fan spin, lights on, etc?
SPECS:
https://linustechtips.com/topic/1229976-no-post/#findComment-13886022
- 24 pin, CPU 8-pin, PCIE power plugged in
- RAM is fully seated
- GPU is fully seated in the slot
- Monitor plugged into GPU
if this doesnt help then:
- try 1 stick on ram on the 2nd slot from the left, or the 4th slot, or the 1st slot, or the 3rd slot
- try reseating the CPU (twist cpu cooler and tilt it gently before pulling up to avoid pulling the cpu with it)
- reseating the GPU
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1229976-no-post/#findComment-13886052
- reseating the GPU
Alright, so i tried to reseat the GPU once more, along with reseating the power cords, and it got a post, thank you
https://linustechtips.com/topic/1229976-no-post/#findComment-13886068
- reseating the GPU
https://linustechtips.com/topic/1229976-no-post/#findComment-13886070
