Would anyone know where I could find used power supply’s? This is the final component I need to finish my gaming PC. I Wish I didn’t have to go second hand but, I have my first child on the way. And with the pandemic raging on funds are very tight, and I’m just looking to get this thing finished before I won’t have the time/money to be able to anymore. I just need something reliable, and powerful enough to power my rig. I think 500-550W should suffice. I will be running a i7-7700 and a GTX 1070 I scavenged from my friends old pre-build. Thank you in advance. And best wishes during these hard times.
https://linustechtips.com/topic/1229118-used-power-supply/
Budget?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1229118-used-power-supply/#findComment-13878783
Were all of your other parts used as well?
https://linustechtips.com/topic/1229118-used-power-supply/#findComment-13878797
  • 2 weeks later...
26 minutes ago, JDcorrectly said:
I'd prefer to stay under $150
I personally recommend this : https://www.tomshardware.com/reviews/be-quiet-straight-power-11-550w-platinum
or this one, https://www.amazon.com/CORSAIR-RM550x-Certified-Modular-Supply/dp/B079HGL413 it has very long warranty iirc, longer than bq one.
No matter how many times I copy the link it copies as the one linking to 650w psu, not 550,not sure what's the issue here.
Edited by nox_
https://linustechtips.com/topic/1229118-used-power-supply/#findComment-13915068
Antec NeoECO Gold Zen NE500G is $69.12 on Amazon (make sure to buy it through Amazon, not the third-party seller) as a budget option.
Edit: Nevermind, it ships September 1st, screw that. The Antec NeoECO Gold 550w is $87 on Newegg.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1229118-used-power-supply/#findComment-13915082
