If you go with the 2.5 inch ssd option you will have to remove you old hdd and put a new 2.5 inch ssd either of the same capacity or a bigger capacity. But if you go with a m.2 ssd you can keep your hdd and just add a second drive on the side but you can only do this if your laptop has support for m.2
https://linustechtips.com/topic/1228863-help/#findComment-13876466
