I was playing with the XFR enhancement in the BIOS setting on the A320m HDV R4.0 Mobo with RYZEN 5 3600 CPU, I when I save and restart my PC. The keyboard and mouse shuts off and the PC stop POSTing. The GPU and fans are powered on but my keyboard, mouse is not, also Ethernet port led nor the HDD led is blinking or lit up. Anyone know what's the issue here?
https://linustechtips.com/topic/1228731-no-post/
clear cmos?
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1228731-no-post/#findComment-13875359
1 hour ago, Kendoko said:
I Tried it, I took the cmos battery out and waited for 30 mins before putting it back on but the issue still persist
when you did this, did you unplug the pc?
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1228731-no-post/#findComment-13875452
Yup
Try these few steps:
1. Remove the cable from the AC to your Power Supply Unit
2. Remove the CMOS battery from the motherboard
3. Press the Power button on your PC chassis or shorting method on the motherboard (This is to "drain" the charges in the capacitors; not sure if this method is legit but at least it works for me)
    3.1. Do this for about 2 minutes and install the CMOS battery.
See if the steps above helps.
https://linustechtips.com/topic/1228731-no-post/#findComment-13875573
