Budget (including currency): around 550 Euro
Country: Belgium
Games, programs or workloads that it will be used for: Esports Titles such as Rainbow Six: Siege and bigger titles such as FarCry on lower settings
System:
- CPU: Ryzen 3 3100
- GPU: Palit StormX OC GTX 1650 Super
- mbo: Gigabyte GA-A320M-S2H
- PSU EVGA 500W 80+ Bronze
- Case: ThermalTake Versa H18 ( acrylic )
- Mem: Corsair Vengeance LPX 16GB (2x8GB) DDR4 3000MHz
- Storage: Sandisk SSD 480 GB
-------Problem-------
So I bought all these components and started to build my first pc. I tested all my components before I put them in the case and all worked fine. I now have put everithing in and there is now no splash screen showing up and I can't get to the bios. I have checked my connections and I'm pretty sure I plugged in everything correctly. I have then searched for a sollution wich was to remove the mbo battery for a couple seconds and then put it back but it didn't work. I don't know what to do now and I would love if someone helped me out... I'm stressed out and tired and don't know what to do... Thank you already.
https://linustechtips.com/topic/1228553-help-me-please/
Welcome to the forums, I would remove everything from the case and bench test the system again, make sure you check where the standoffs are installed in the case as one simply being in the wrong spot under the motherboard could be connecting with something it shouldn't.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1228553-help-me-please/#findComment-13873936
I have now started the system with a ram stick in another slot every time with both of the ram sticks, but no results... And could you clarify what you mean by "Clear CMOS?". I have already removed the mbo battery a couple times if that is what you mean.
https://linustechtips.com/topic/1228553-help-me-please/#findComment-13874035
I have now tried to clear CMOS by holding a screwdriver against the two jumper pins, because I don't have the jumper to put on there, while starting up the system. It did nothing so I turned the system off and turned it on again without the screwdriver against the pins but it didn't do anything. Maybe I did it wrong, tell me if I did... And any other sollutions maybe???
https://linustechtips.com/topic/1228553-help-me-please/#findComment-13874096
