Hi, I am thinking about upgrading to 32gb of RAM. My questions are as follows:
1. If I use my all four memory slots does it matter if I have two separate pairs? ie a pair of Corsair vengenace and a pair of Kingston Hyper Xs
2. If the answer to 1. is no should I use all 4 slots or just use 2? ie get two more 8gb sticks or just do away with the old and get a pair of 16gb sticks?
My CPU is a Ryzen 7 2700x MB is a AsRock B450 Steel Legend. Thanks for the help as I am just starting to learn about PCs.
https://linustechtips.com/topic/1227900-ram-help/
1. If I use my all four memory slots does it matter if I have to separate pairs? ie a pair of Corsair vengenace and a pair of Kingston Hyper Xs
If you want the best performance possible, you ideally want to have matching modules for all 4 slots. Depending on your workloads, you could suffice using two different pairs.
Basically, having a pair of Corsair Vengenace and a pair of Kingston Hyper Xs will work. It just won't be the best.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1227900-ram-help/#findComment-13868441
So I just looked and my processor is only dual channel capable so would it even work trying to use the 4 slots?
https://linustechtips.com/topic/1227900-ram-help/#findComment-13868452
