Hello! I have a high-end gaming PC with a 1440p monitor. However pretty much every game I play I don't get as much of fps as I should. For example, I play warzone on low to med settings and only get around 120 fps (I play at 1440 p). My friends that I play with have less powerful GPU and get more fps than me even if I switch to 1080p. Please help as I've tried so many things and I'm getting stressed out.
Specs:
OS: Win 10 PRO 64 bit
GPU: MSI Trio RTX 2080 Super
CPU: AMD Ryzen 3700x
RAM: 32 (4x8) GB DDR4-3200
MB: Asus x-570 PRO
PSU: 750 W 80+ Gold
SSD: 970 Evo 500 Gb with windows
HDD: 2 TB
PSU: Corsair RM (2019) 750 W 80+ Gold
Monitor: LG 27GL850 set to 1440p + 144 hz in windows and the games.
USERBENCHMARK RESULTS:
https://www.userbenchmark.com/UserRun/31077778
Problem:
As more youtube videos I watch with my CPU and GPU as well as asking my gamer friends everyone gets more fps than I do.
In Cod WZ, I get around 100 to 120 fps on 1440p, while on 1080p I maybe get 140 fps. This is all on pretty much on minimal settings.
BattleField 5 on ULTRA 1440p runs at 80 fps, but when I look at youtube videos that have my gpu and CPU they get 100 to 140 fps on 1440p and ULTRA settings.
Also, on this website, it says what FPS I should be getting with my system components.
https://www.gpucheck.com/game-gpu/call-of-duty-modern-warfare-2019/nvidia-geforce-rtx-2080-super/amd-ryzen-7-3700x/ultra
What I've tried:
Reinstalled the game.
Updated every possible driver imaginable, chipset, bios, Nvidia etc.
Following the instructions here
View: https://www.youtube.com/watch?v=_KsK55zgUAQ&feature=youtu.be
however it boosted maybe 10 fps in WZ, however, the game looked awful so I reset everything to default besides DSR factor (set to off) and power management (set to Max Performance)
Monitoring temps - my CPU is around 55 C and GPU is around 75 C when under HEAVY (Streaming and Playing WZ) load.
I have also disabled fastboot, gamer ba/ mode whatever, all overlays, etc.
I also enabled performance mode in Power settings.
Wiped all the drives and Cleaned installed windows.
Emabled D.O.C.P for ram in Bios, and set it to 3200 mhz.
What I have not tried:
I'm not so comfortable with BIOS tweaking so I didn't touch that part at all besides updating.
Please help! Thank you for taking your time and helping me out!
https://linustechtips.com/topic/1227218-system-underperforming/
DdU the Nvidia driver and I stall a clean one without geforce bloatware.
Also, don't use userbenchmark, it's a known fraudulent site and is banned in r/intel, r/AMD and r/hardware because of manipulated data.
As for what you can do, disable game mode and game bar, make sure you're not running any weird broken overlays and use Fire Strike to compare scores. I'd your scores there are normal, the issue is a software one with the GPU likely.
https://linustechtips.com/topic/1227218-system-underperforming/#findComment-13862891
Yeahh loooool
I dont understand how a 9600k out performs a 3900x BRUH
this is a real scam...
Says that a 8700k is better then a 3800x Pffff.........
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1227218-system-underperforming/#findComment-13862962
Plus it COD Warzone always seems to have shit FPS regardless of what spec you have
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores - Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD & 2x 1TB Seagate Drive OS: Win10
https://linustechtips.com/topic/1227218-system-underperforming/#findComment-13862989
Hey so I did DDU, however I can't get fire strike. Instead I used superposition benchmark and here are the results. Before DDU Superposition benchmark and got 7306 (1920x1080 extreme) and 10465 for 2560 x 1440 || After DDU for 1080p extreme 7203 and 4131 for 1440 p.
https://linustechtips.com/topic/1227218-system-underperforming/#findComment-13864273
They appear normal. Are clocks/temps normal?
https://linustechtips.com/topic/1227218-system-underperforming/#findComment-13864328
